Heat Won't Stop Running, Just Installed New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 06:05 PM   #1
Heat won't stop running, just installed new thermostat
So this is prolly my bad...But here's the situation.
I just installed a new programable thermostat (model 3M-25)
I followed the instructions pretty well but the provided wiring diagrams did not match my wires exactly.
I had a wire labeled R2, but no Rc or Rh.
Anyhow after poking around 3M's website I saw that R is a hot wire for the heat so I hooked it up to the Rh on the thermostat and the a/c has worked just fine.
But now its getting cold, so I turn on the heat.
I have the heat programmed at 70F.
So it gets cold and the heat cuts on at the correct temp.....
But it just stays on...until I manually turn it off...
I mean it was 79F when I got home today.....
Anyhow I could use some help..
NorthSidePK is offline   Reply With Quote
Old 10-29-2012, 06:22 PM   #2
Rewards Points: 196
What are the other wires hooked to, and what type of equipment.Usually W=white G=green Y=yellow/blue R or RH & RC =red
HVACTECH96 is offline   Reply With Quote
Old 10-29-2012, 06:34 PM   #3
I have C,B,O,W2,Y,RH & G connected on the new thermostat
The old thermostat had C,B,O,W2,R,& G connected
I hooked the wired labeled R on the old to the RH on the new
The new has W,Y2, & RC empty and unconnected
The heater is electric and has Goodman model A24-08 marked on it
Thanks for the help BTW
Old 10-29-2012, 06:37 PM   #4
O is orange
G is green
C is white
W2 is White
R is red
Y is yellow
B is black
Old 10-29-2012, 06:40 PM   #5
AKA HVACTECHFW
Rewards Points: 1,208
Sounds like you have a heat pump. Did you setup the stat for that? Did you use the HP terminal designations?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-29-2012, 06:42 PM   #6
Rewards Points: 196
is this air to air heat pump
Old 10-29-2012, 06:43 PM   #7
I have the jumpers set for elec heat.....I guess I could change it to the heat pump setting to see if it helps...
Whats the difference between a heat pump and an elec heater? if you dont mind me asking??
Old 10-29-2012, 06:46 PM   #8
Rewards Points: 196
heat pump uses freon ran in reverse direction and electric is usually strip heaters in an air handler.
Old 10-29-2012, 06:51 PM   #9
So my jumpers go like this:
1-on=24hr clock <-----I have no jumper on 1
1-off=12hr clock
2-on=Celsius disp. <----I have no jumper on 2
2-off=Fahrenheit Disp.
3-on=Gas/oil Heat <----I have no jumper on 3
3-off=no fan
4-on=elec heat <----I have no jumper on 4 ( i just took it off)
4-off=no fan
5-on=heat pump <----I have a jumper on 5 (I just put it on)
5-off=normal
6-on=HP-AUX Only <-----I have no jumper on 6
6-off= normal
7-on=RC-RH connected <-----I have a jumper on 7 (should I??)
7-off=RC-RH separate
8-on=gas/oil HP AUX <--------I have no jumper on 8
8-off= elect HP-AUX
Does this sound correct?
Old 10-29-2012, 06:54 PM   #10
AKA HVACTECHFW
need the jumper on 4.........
IT IS WHAT IT IS
Old 10-29-2012, 06:55 PM   #11
ok, so I have a jumper on 4,5 and 7 now.....
Old 10-29-2012, 06:58 PM   #12
AKA HVACTECHFW
not sure if 6 should have one or not I would have to look up your stat install instructions.
IT IS WHAT IT IS
Old 10-29-2012, 07:08 PM   #13
The wiring diagram that is closest to mine in the stat install manual is a 5-wire heat pump with aux heat.
the diagram shows C,W2,Y,RH,G and B or O for a total of 6 wires...
I have 7 wires, cause I have a B and an O....
Either way it sounds like I should jumper 6...right?
Old 10-29-2012, 07:08 PM   #14
Rewards Points: 74
post model number of units so folks can tell you what you have
digitalplumber is online now   Reply With Quote
Old 10-29-2012, 07:13 PM   #15
Model numbers ar 3M-25 on the thermostat
and
goodman a24-08 on what I thought was an elec heater...but is actually a heat pump..
Goodman Electric Heat Continously Running jrice41159 HVAC 3 11-27-2011 06:56 PM
Replacing thermostat, no heat (heat pump, 2 stage heat, 1 stage cool) BrianJM HVAC 20 09-28-2011 09:53 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
Installed new thermostat, killing fuses when switching to heat carsnrockmusic HVAC 8 11-03-2010 08:11 AM
