Heat Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 10:20 PM   #1
Heat Won't Shut Off
I have a 1998 Bryant model 383KAV024045 Gas furnace. The unit runs with heat activated with blower and flame no matter what the thermostat calls for (Off, Heat on, AC ON, and above and below set temp in all modes) The only way I can shut it down is to cut the gas and wait a few minutes for cooling so I can cut the power. Any ideas what the problem is? I'm thinking a relay or something?
I already tried replacing the stat.
Ideas would help.
jsant1070 is offline   Reply With Quote
Old 05-11-2010, 12:18 AM   #2
sounds like it may be the board, inspect it for areas that appear to be burnt or charred, also check that your thermostat is not mis-wired.
tamar120 is offline   Reply With Quote
Goodman Heat Pump - Blower Motor FireFighter254 HVAC 9 03-05-2010 06:18 AM
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 06:32 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
Programmable thermostats, heat pumps and aux heat Crunkleton HVAC 3 04-21-2009 05:17 PM
