Old 11-21-2006, 10:31 PM   #1
heat wont come on with t-stat in auto
fan wont come on when t-stat on "auto" and in heat, but it does in cool. Unit will heat a little when t-stat fan switch "on". Have heard that the a/c compressor runs backwards for heat. Does not engage in heat.
The electric elements under fan do heat up.
I have an Intertherm a/c-heat pump unit.
Please help
wahanks is offline   Reply With Quote
Old 11-22-2006, 02:55 PM   #2
Thoroughbred Mopar Man
Hi wahanks
Very seldom does a thermotat need to be replaced, but in your case it sounds like either the cooling anticipator is going out or the subbase is bad. Either way from your description you need a new thermostat. The ones I would reccomend to replace with are White Rogers 1F82-261 for programmable or 1F89-211 for a non programmable. Let us know if we can help further.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Commercial heat tape. rforsha Electrical 3 12-04-2007 08:41 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
