Heat Strip - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 07:50 PM   #1
heat strip
need to know how to wire strip heater on goodman heat pump 2.5 ton mod 30 on air handler no diagram
shooter one is offline   Reply With Quote
Old 12-12-2010, 08:55 PM   #2
HVAC / Plumbing
you'll need to know more than that . You'll need to AMP draw. Your existing wire to the unit may not be large enough to add heat strips
kenmac is offline   Reply With Quote
Old 12-13-2010, 04:46 AM   #3
An old Tradesmen
Rewards Points: 7,356
Are you replacing an old one. Or adding one to a unit that never had one. If adding one, Did you get the complete kit. Or did you just order a replacement heater.
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
Ruud heat strip furnace blower TKELLY HVAC 4 03-08-2010 02:09 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 01:17 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
