Old 12-12-2012, 06:40 PM   #1
Heat Sequencer Relay
Could someone give me a current replacement part number for the following?
T-O-D
12SH22 H24V 305499
HQ1056789TD
H1-20 C40-110
L9618
chig is offline   Reply With Quote
Old 12-12-2012, 07:08 PM   #2
Hvac Pro
HQ looks like an OEM ICP part #. Have to get it from them. Your pic won't show up in my browser. Need to attach it as a JPEG for most users.
Old 12-12-2012, 07:25 PM   #3
Experienced HVAC Tech
I can only find a similar one at carrier. Is your furnace a carrier brand? Though I think it may be an ICP part also
HVAC1000 is offline   Reply With Quote
Old 12-12-2012, 09:43 PM   #4
It's a Goodman A36-05 air handler. Here's the proper link to the image...
I already bought the wrong relay, p/n B13707-38, but at least it was only $14.
Thank you for helping!
Old 12-12-2012, 09:48 PM   #5
Missouri Bound's Avatar
Posting your location could prove helpful. If there is a Grainger or Johnstone supply near you you may find one there. It's not an unusual part.
Do you want it your way or the right way?
Old 12-12-2012, 10:23 PM   #6
Both are close by in Clearwater, FL. I'll check them out in the morning. I didn't even think of Grainger. Thanks!
Old 12-12-2012, 10:25 PM   #7
Look around the Grainger website first. It may help you when you get there to know a part number or a general term of reference.
Heat won't stop running, just installed new thermostat NorthSidePK HVAC 28 11-01-2012 11:05 AM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 09:07 AM
Wiring a Honeywell RA89A Relay shawnmd HVAC 7 10-21-2010 07:58 PM
Goodman Heat Pump - Blower Motor FireFighter254 HVAC 9 03-05-2010 07:18 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
