Heat Sensors - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 04:10 PM   #1
Heat sensors
Where are my heat sensors located on my 9200 Carrier Weather Maker Furnace
kaydee1985 is offline   Reply With Quote
Old 01-08-2009, 04:31 PM   #2
Are you referring to the limit switch and spill switches? If so, the limit switch looks like a card with two wires and is mounted to the firewall. The spill switches are round, nickel sized, with two wires and sometimes a reset button. They are mounted in various locations around the burner box.
SKIP4661 is offline   Reply With Quote
Old 01-08-2009, 05:18 PM   #3
he might even be refering to the flame sensor!
If it's true that you learn from your mistakes- I'm getting one heck of an education
thumbkins is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 03:57 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
