Old 08-20-2006, 10:30 PM   #1
heat rises
I own a two story A frame home and the ac works fine but the upstairs temp is aprox. 10 degrees warmer. the home has been remodeled, all looks good except I noticed the air returns are located next to the cold air vents, and is the same in both upstairs rooms. Should the return air register be located between the rooms, and or should it be up high because heat rises?
Aframeowner is offline   Reply With Quote
Old 08-21-2006, 06:39 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
heat rises
I also own an A-frame.
The return registers should not be near the supply vents, as it will draw the cold or warm air immediately out of the room, and they should be as high as possible.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-21-2006, 11:09 AM   #3
heat rises
That,s what I thought. The preveous owner must have done that himself without even checking online like I am. Thanks for the info.
Old 08-21-2006, 05:45 PM   #4
heat rises
Is there any type of attic space?
redline is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 04:43 PM
heat wont come on with t-stat in auto wahanks HVAC 1 11-22-2006 02:55 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
