Heat Register Reroute - HVAC - DIY Chatroom Home Improvement Forum
Old 12-03-2013, 02:14 AM   #1
I am in the process of completing my kitchen which I tore down to the studs and subflooring. I reconfigured the cabinetry and now I need to go under a cabinet and put the register on the front of the cabinet. It is a 12x4.
I've been to four hardware stores and none of them carry a 90 degree angle piece or additional pieces of the rectangular sheet metal (assemble two pieces together) to reach the front of the cabinet in 12x4 size. All I can find is 10x4.
So, I bought 10x4 with a 6 inch diameter on the other end that already has a 90 degree plus additional sheet metal to reach the front of the cabinet. Should I be going this route or does anyone have suggestions about finding 12x4? I'm in the Seattle area so we have most every store around.
Thanks.
Rebster is offline   Reply With Quote
Old 12-03-2013, 07:50 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
use the 10x4 as the 6" hole is what really determines the airflow. you won't notice any difference.
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 07:07 AM
how to add a heat register Joyce H Remodeling 2 10-25-2011 09:03 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
