Old 07-20-2011, 06:54 PM   #1
heat pumps outside unit is broken.
I live in northern NJ and I have a Trane heat pump with Aux heat. My outside unit just stopped working and my AC guy says the compressor need to be change. What if I change the whole outside unit? Do I need to change the inside unit as well (the evaporator)? Since I am not able to afford a Trane outside unit I am thinking about getting a Goodman? It is compatible with my current inside units? Any suggestion is appreciated.
Nora.
NoraZar2011 is offline   Reply With Quote
Old 07-20-2011, 08:17 PM   #2
Heat pumps are pretty touchy when it comes to indoor and outdoor coils matching. I'd stick a new compressor in the Trane before buying half a mismatched system.
Old 07-20-2011, 09:32 PM   #3
An old Tradesmen
If you want it to work right. need to also get a new AHRI rated matching indoor unit, or atleast a new indoor coil.
my central a/c heat unit trips my 40 amp breaker after running heat for 5 minutes. buttons1 Electrical 2 12-27-2010 10:23 AM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Compatability question (cooling unit to heat pump) Common HVAC 2 10-28-2009 08:44 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 04:08 AM
