Need some help please, I have moved into a house that is about 10-year-old. The A/C seemed to work fine but I have tried the heat and it’s not working right. Here what it’s doing. When I turn the thermostat to 72 the heat pump will turn on outside. I go upstairs and removed to furnace cover and can feel the heat off the coils. But after maybe 10 minutes the outside unit turns off and the aux turns on. Now when the thermostats get to the set temp the heat turns off but the blower fan won't. I can get the fan to stop blowing by turning the temp down by 1 degree. I have two units and both act the same. Anyone have an idea what to check also both Thermostat have the check light flashing.
It not the defrost mode. I can manually set the defrost on one unit but not the other by shorting the test pins on the defrost board plus the either unit builds up ice.
I've removed the brown and red wire from the thermostat and jumped them together and the heat pump turned on but shut off after some time. Found this on the defrost board.
Does it always move to aux after 10 mins every time? I would suspect there might be something in the thermostat set up if that is the case. eg.. it will run on heat pump for 10 mins and if demand isn't satisfied it will energize aux heat till cycle complete.
The thermostat manual indicated that the differential was adjustable for both first and second stage heating. Do you know what that differential is set at?
I set the differential to 2 degree on both units default is 1. Heat turned on today I went outside and both units were off. I turned both breakers outside off then back on and waited 5-6 minutes and neither turned back on.
Should have turned the breakers to the inside units off, and then back on. Not the outside unit breakers.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
