Heat Pumps, Large House, And Efficiency-Stage 1 Vs. 2 Vs. 3 - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 01-10-2017, 01:52 PM   #16
Rewards Points: 1,684
Re: Heat pumps, large house, and efficiency-Stage 1 vs. 2 vs. 3
Originally Posted by user_12345a View Post
-10f is a bit of a strech, it may save a little bit but the heat output is probably so low, it's not worth the wear.
traditional air source heatpumps aren't suitable for frigid weather.
It's not a stretch at all. The heat strips are active on a supplemental basis at that temp so it doesn't run for as long as you would think. It's still 15,000 btu coming in at less than the same value in on a heat strip.
Bob Sanders is online now   Reply With Quote
Old 01-10-2017, 05:40 PM   #17
An old Tradesmen
Rewards Points: 6,112
Might only save the OP 15 bucks a month, or it could be 30 bucks a month at -10F. Depending on the defrost board. On demand will basically only be defrosting once every 6 hours of compressor run time when its -10 outside.
So if the OP is at a COP of 1.3 at -10F, he is getting 30$ more heat per dollar from it, then what his resistance heat gives.
Old 01-10-2017, 05:48 PM   #18
Rewards Points: 38
For reference, my electric bill was $628 last month (early December to early January) and it wasn't even that cold save for a few days, so though it may seem like I am splitting hairs, this could end up real money over time.
CaptainHook is offline   Reply With Quote
Old 01-10-2017, 06:18 PM   #19
Wow.
I'm in Manitoba Canada... MUCH colder than you and my total electric bill for dec-jan was $322 (3417 Kwh)
How much are you getting scalped for electricity?
Old 01-10-2017, 08:36 PM   #20
Rewards Points: 38
Originally Posted by Bob Sanders View Post
Wow.
4587 kWh, so about $0.1369/kWh.
You have a heat pump in Manitoba?!?
Old 01-10-2017, 08:47 PM   #21
Yeah, that explains it. We're at about $0.076
Don't like gas. With the price of electricity here a good heat pump works out to about the same as a mid efficient gas furnace. This is our second year with a HP and it has worked out quite well. The only pain is keeping the condenser free of ice and snow.
Old 01-11-2017, 03:35 AM   #22
Rewards Points: 42
Ours is closer to $0.23/kw.h after extra distribution and fees. (Ontario) My heat pump was older and not sized like yours, so I'd expect +$500/month during January now if I was still on it. (4-6Mwh) Down to below $80/month on gas. (annualised it's about as high as the furnace before labour)
Cheers!
supers05 is online now   Reply With Quote
Old 01-11-2017, 05:43 AM   #23
Cheers!
Yeah, the Ontario power is crazy.... highest in the Country I think? The gas is going to go up though because of the carbon tax. It won't be much at first, but it'll start spiraling up over time.
Old 01-11-2017, 08:10 AM   #24
Rewards Points: 42
Electricity will follow suit.... A good portion of our peak electricity is NG generated....
Cheers!
Old 01-11-2017, 02:02 PM   #25
Rewards Points: 6,742
all of the peak capacity is gas; the gas is also used to backup wind farms which are so unreliable that there are no fuel savings. should have just kept the coal plants and put scrubbers on the smoke stacks, would have been a lot cheaper with only a little more smog forming pollution.
The carbon tax is harmful where there is no alternative to fossil and nuclear fuels. the only forms of renewable power generation which make sense are geothermal and hydro. most places don't have the right geography for those.
My Backround FIY: I am not in any aspect of the HVAC business now but have formal education + some DIY experience. Theory is not a substitute for experience; neither is "old school" experience an excuse to not understand or practice the theory.
user_12345a is online now   Reply With Quote
Old 01-11-2017, 06:09 PM   #26
Cheers!
Yeah... forgot about that. In Manitoba most of our power is hydro.
Old 01-11-2017, 06:13 PM   #27
Rewards Points: 42
The already had state of the art scrubbers on Nanticoke. They actually made money from selling the solid waste.... Anyways, can't change the past....
Cheers!
Old 01-11-2017, 11:00 PM   #28
Rewards Points: 42
Thanks for the replies. This morning it was approximately 18 degrees and I noticed that the upstairs heat pump did turn off temporarily as it reached the thermostat setpoint of 68 degrees. I have outdoor units 4TWX6060B1000A and 4TWX6060A1000A but am not able to locate any published COP. This is the only information I was able to find:
"A.R.I. STANDARD 210/240 RATING CONDITIONS (A) Cooling 80F. D.B., 67F. W.B. air entering indoor coil, 95F. D.B. air
entering outdoor coil. (B) High Temperature Heating 47F. D.B., 43F. W.B. air entering outdoor coil, 70F. D.B. air entering indoor
coil. (C) Low Temperature Heating 17F. D.B., 15F. W.B. air entering outdoor coil, 70F. D.B. air entering indoor coil. (D) Rated
indoor airflow for heating is the same as for cooling."
I am unclear on what "D.B." and "W.B." mean.
DB = dry bulb (fancy name for a thermometer)
WB= wet bulb (a thermometer with a wet material around the bulb. It sounds for humidity.)
http://www.comfortsouth.com/files//51-17411.pdf
Cheers!
The Following User Says Thank You to supers05 For This Useful Post:
CaptainHook (01-12-2017)
Old 01-11-2017, 11:55 PM   #29
Rewards Points: 42
https://elibrary.comfortsite.com/lol...sted_filename=
Cheers!
Old 01-12-2017, 12:51 AM   #30
Rewards Points: 42
Apparently I'm not very adept at using Trane's portal. I can't find the extended performance data for that model number....
Cheers!
Controlling When Aux Heat Pump Heat Comes On kckranz HVAC 20 12-21-2016 07:57 AM
Dual fuel heat pump thermostat help pug_patrol HVAC 4 02-14-2016 07:51 AM
Heat pumps and back-up furnace bluefoxicy HVAC 20 03-10-2013 04:35 PM
gas furnace efficiency, hybrid heat pump, and payback times av-geek HVAC 1 06-22-2012 08:46 AM
Heat Pump Efficiency Help! horseonthefly HVAC 5 03-16-2012 05:14 PM
