Heat Pump Won't Kick On?? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 08:57 AM   #1
Rewards Points: 150
Heat pump won't kick on??
SO just all of sudden it won't kick on....The stat still reads heat on and Aux heat on but nothing happening.....Won't work on cooling setting either. I reset all the breakers to make sure but still nothing.....The unit is 6-7 years old. and it has been a very easy winter on it.......Any ideas or things to check before I call someone??? I did replace the stat with a programable one but that was a month ago and its been working fine and I have made sure it wasn't set wrong or anything.
organick is offline   Reply With Quote
Old 03-25-2012, 09:37 AM   #2
HVAC Tech/ Browns Fan
Is the blower coming on when call on Fan on only by the stat
Tator1076 is offline   Reply With Quote
Old 03-25-2012, 10:30 AM   #3
Rewards Points: 150
nope the fan doesnt come on even when set to on . nothing
Old 03-25-2012, 11:12 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
transformer possibly went KapOot.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 03-25-2012, 08:06 PM   #5
thermal-medics.com
pull the t-stat
pull the cover off the t-stat and touch red and green... still nothing (no indoor blower motor)?
look in the air handler cabinet for a small fuse and see if its blown. 5 amp or something like that
did you have any thunder storms/power surges lately.. seriously
thermal-medics is offline   Reply With Quote
Old 03-26-2012, 07:17 AM   #6
Rewards Points: 150
I will check that will the fuse be obvious somewhere????
yes lots of nasty thunderstorms.
Old 03-26-2012, 09:50 AM   #7
thermal-medics.com
split system or package.
thinking split so pull the power or disconnect to the cabinet and look inside you will see the transfomer and usually a fuse with 5 or something on it. you can check the schematic too or just throw up some pics
Old 03-26-2012, 10:20 AM   #8
Rewards Points: 150
split system.......nothing when touching the stat wires.....will check that fuse tonight. thanks
Old 03-27-2012, 03:15 PM   #9
Rewards Points: 150
ok can't find a fuse anywhere.....that being said I switched out the stat with the old one which powers off the common wire but no juice??? if that helps??
Old 03-27-2012, 08:01 PM   #10
Rewards Points: 1,192
Check power at main contactor.
bobelectric is offline   Reply With Quote
Old 03-27-2012, 11:38 PM   #11
thermal-medics.com
dang thats frustrating, any chance of a pic of that air handler or a model no?
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 03:34 AM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
New heat pump wiring question jmedenf HVAC 3 10-14-2011 06:26 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 05:13 AM
