Heat Pump Wiring Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 05:03 PM   #1
heat pump wiring problems
I am trying to figure out my thermostat wiring. I have a goodman heat pump with heat strips, package unit. The problem is that anytime the unit is running, heating or cooliing the heat strip is activated.
I belive I see the problem, and think it is the jumper between the w and y terminals.
I have always just turned the heat strip off at breaker unless the heat pump couldnt keep up, and then turned on so no big deal, but now we are selling house and I want it to be correct.
Can anyone tell by my pics what the problem is for sure and if it looks right or not.
The wires connecting inside the heat pump unit are all color matched, and I belive some are more than 2 wires togather. If I need to will take pic and post as well.
Thanks for any help/suggestions.
outside wiring.
Alan
zskyman is offline   Reply With Quote
Old 07-24-2012, 05:13 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
yes, that jumper should not be there if the white wire is wired to W in the HP.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-24-2012, 05:19 PM   #3
looks like a tstat not made for heat pump with aux heat backup. Is your heating bill high? the way its wired heat pump and electric heat would run at the same time.
turnermech is offline   Reply With Quote
Old 07-24-2012, 05:27 PM   #4
thanks...i have added pic of outside wiring now...there is a brown also in with the white....is that correct still for pulling the jumper between w and y..
alan
Old 07-24-2012, 05:30 PM   #5
AKA HVACTECHFW
maybe, what is the model number of the thermostat?
IT IS WHAT IT IS
Old 07-24-2012, 06:21 PM   #6
thermostat is a rite temp 6010 it looks like...
Old 07-24-2012, 06:26 PM   #7
AKA HVACTECHFW
leave the jumper but move the white wire to w2 or disconnect at both ends.
IT IS WHAT IT IS
Old 07-24-2012, 06:32 PM   #8
what about the brown that is there now...remove or leave and move white wire to w2 also.
Old 07-24-2012, 06:36 PM   #9
one last thing...the blue wire...that is the common wire and stays on c...right.
Old 07-24-2012, 06:38 PM   #10
AKA HVACTECHFW
Leave brown and connect white also to W2. Yes, blue stays on C.
IT IS WHAT IT IS
Old 07-24-2012, 06:59 PM   #11
ok...made the changes...but heat strip still seems active even on ac...meter is spinning fast....but when turn off heat strip at breaker it slows back down...so it is still active.
Old 07-24-2012, 07:03 PM   #12
AKA HVACTECHFW
then you have a bad stat and it is sending a signal on W2 during a call for cooling. You should only have the jumper on W and no other wires. Post a picture of the new wiring.
IT IS WHAT IT IS
Old 07-24-2012, 07:05 PM   #13
AKA HVACTECHFW
See page 10 of the PDF for wiring illustration.
http://www.ritetemp-thermostats.com/...tion_guide.pdf
IT IS WHAT IT IS
Old 07-24-2012, 07:09 PM   #14
i was looking at page 17...heat pump with auxillary heat...but seems to be right according to that..just obviously not right if heat strip run while ac is running..
sorry to be so much trouble...its just driving me nuts trying to figure it out.
Old 07-24-2012, 08:44 PM   #15
AKA HVACTECHFW
Remove wires from w2 and test. If it works w/o strip heaters then it is the stat.
IT IS WHAT IT IS
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
wiring heat pump and air compressor outside building lcvette Electrical 3 07-28-2011 01:32 PM
Heat Pump Low Voltage Wiring bobolink2000 HVAC 10 05-01-2010 09:50 AM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
Wiring a RobertShaw 9870i to Gas Furnace & Heat Pump jerfer HVAC 11 12-21-2008 09:09 PM
