Heat Pump Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 03:54 PM   #1
heat pump wiring
wiring pro t925 thermostat to luxaire heat pumpwith heat strips in air handler
Grossetete is offline   Reply With Quote
Old 10-05-2012, 04:13 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
model numbers of HP and air handler? Link to thermostat manual? Is this a replacement? If so how was the old stat wired? NEED MORE INFO.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-05-2012, 04:37 PM   #3
heat pump wiring
Have new system installed Luxaire THJF24 heatpump, AVG24 air handler with pro iaq t925 thermostat. Installer not happy to wire unit so will wire it myself. any help is appreciated
Old 10-05-2012, 04:43 PM   #4
heat pump wiring
Also has heat strip in air handler
Old 10-05-2012, 05:33 PM   #5
An old Tradesmen
Rewards Points: 6,142
What brand is the thermostat?
Old 10-05-2012, 06:19 PM   #6
Houston204's Avatar
Rewards Points: 556
http://www.upgnet.com/PdfFileRedirec...btg-b-1010.pdf
http://www.pro1iaq.com/resources/ins...anual_t925.pdf
Houston204 is offline   Reply With Quote
Old 10-05-2012, 07:27 PM   #7
An old Tradesmen
Your slipping. Normally you would have a wiring diagram for it posted already.
Old 10-07-2012, 10:09 AM   #8
AKA HVACTECHFW
IT IS WHAT IT IS
heat pump wiring problems zskyman HVAC 17 07-26-2012 05:55 AM
gas furnace efficiency, hybrid heat pump, and payback times av-geek HVAC 1 06-22-2012 08:46 AM
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 04:34 AM
Heat pump motor wiring 70sixspeed Electrical 2 10-29-2011 01:21 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
