heat pump wiring
wiring pro t925 thermostat to luxaire heat pumpwith heat strips in air handler
model numbers of HP and air handler? Link to thermostat manual? Is this a replacement? If so how was the old stat wired? NEED MORE INFO.
heat pump wiring
Have new system installed Luxaire THJF24 heatpump, AVG24 air handler with pro iaq t925 thermostat. Installer not happy to wire unit so will wire it myself. any help is appreciated
heat pump wiring
Also has heat strip in air handler
What brand is the thermostat?
Your slipping. Normally you would have a wiring diagram for it posted already. :thumbsup: |
| All times are GMT -4. The time now is 11:40 AM. |
