Heat Pump Will Not Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2007, 03:22 PM   #1
Heat Pump will not turn on
For some reason the entire system has stopped working. The Air Handler does not even come on or the unit outside. I checked the main breakers inside, outside and on the unit itself. All okay and reset them just to make sure.
Thermostat is about a year old but wondered if that could be the problem. Replaced the thermostat and still does not work. Outside unit is maybe 2 years old and the air handler is 5. The thermostat says the heat is on but nothing going on in the system.
I assume it's an electrical problem but wanted to see if anyone had any suggestions. Thanks.
beakon20 is offline   Reply With Quote
Old 12-06-2007, 10:11 PM   #2
Send a message via Yahoo to mrkool
My guess is the transformer is shorted out, unless it has a 3 or 5 amp fuse
inline on the hot side, like most of the new stuff has.
If you can see where the thermostat wires connect at the indoor unit (furnace), and take the wire nut off the green and red wires, then separate
the red wires and touch the red from the unit to the green and see if the blower comes on, if yes, problem is not the transformer or fuse, if no blower,
then it is probably trans or fuse.
Most furnaces have circuit board inside to control everything and sometimes
there is a fuse on the control board, should be a blue 3 amp, but maybe 5 amp.
Let us know
ps: it would be nice to have a volt meter, they only cost about $10 these days.
mrkool is offline   Reply With Quote
Old 12-07-2007, 07:04 AM   #3
I was thinking the transformer when I first opened the panel. I have the multimeter was going to check the circuits out today. Thanks for the advice.
Old 12-07-2007, 08:16 AM   #4
Checked transformer this morning. No inline fuse except for the breaker on the actual incoming 240 line. No circuit board that I can see unless it is somewhere else on the air handler. Transformer has 240 going in but nothing going out on the 24 VAC side so it's the transformer.
Old 12-10-2007, 01:22 PM   #5
Fixed
New transformer came today and we are back online again. Local hvac companies wanted $$$ for the part and to install the part even though I already told them what the problem was.
Old 08-22-2008, 02:53 PM   #6
Hi, sorry to revive a dead thread, but I am having a somewhat similar problem. I took this advice (thanks):
Let us know
BUT, in my case, the blower came on. Which is nice for the time being, but obviously not an ideal long-term solution. Since it's apparently not the transformer, is there anything I can check next or is it time to call the HVAC guy?
lowercase is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 03:00 PM
heat pump dreck HVAC 2 09-11-2006 07:18 PM
heat pump not working kyleGR HVAC 2 05-30-2006 02:35 PM
