Heat Pump Vs Traditional Gas System - HVAC - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 09:41 AM   #1
Rewards Points: 50
Heat Pump vs Traditional Gas system
Is there a time when you dont consider Heat Pump, say like a poorly insulated house?
or does it boil down to something else?
digitalplumber is offline   Reply With Quote
Old 10-31-2012, 11:00 AM   #2
Rewards Points: 6,652
Depends on how airtight the home is. You can have a home with no insulation in the walls, but have every crack sealed, and the system will work as good as if the walls were insulated.
The Following User Says Thank You to gregzoll For This Useful Post:
digitalplumber (10-31-2012)
Old 10-31-2012, 12:47 PM   #3
Rewards Points: 446
The heat pump won't know what kind of house it's in any more than the gas furnace.
Deciding what kind of heating system to use is a choice driven by efficiency, cost to install, comfort during operation, cost to operate and personal preference.
Sizing of a system into a home with poor insulation may eliminate a heat pump system simply because you can't buy one big enough or don't want to put more than one system in.
If it comes down to spending money, in most cases I suggest you spend the money on insulation and tightening up the home first. After you have the home efficient you can put in a system that should never be too big. Being too big for the home makes a system short cycle with costs more to operate, makes the home less comfortable and in most cases will seriously shorten it's useful life.
old_squid is offline   Reply With Quote
The Following User Says Thank You to old_squid For This Useful Post:
Old 10-31-2012, 01:43 PM   #4
Rewards Points: 706
So the wood or coal stove in the center of the one room school was complete ignorance ?
Old 10-31-2012, 02:33 PM   #5
HVAC Tech/Owner
Rewards Points: 604
When we do an oil furnace to hp conversion we do a whole house analysis of the house. Included in our quote (through a partnership with a local insulator) we include bringing up the insulation to current code.
Technow is offline   Reply With Quote
The Following User Says Thank You to Technow For This Useful Post:
Electric baseboard VS Heat pump Mattme123 HVAC 20 09-21-2012 09:41 PM
Heat Pump Crisis, Help! Doc Holliday HVAC 14 12-02-2011 10:22 PM
heat pump system is heating when on cool setting every 3-4 days???? tommy56 HVAC 4 08-09-2011 08:24 AM
Heat Pump, dual system, all electric, compressor not working rlc5669 HVAC 16 01-04-2011 08:59 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
