Heat Pump Vs Straight Cool? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 10:55 PM   #1
Heat Pump vs Straight Cool?
Ok,
Just bought a house in SW Florida (North Port, FL...North of Fort Myers). I need to replace the 11 year old Rheem Heat Pump. I called in one company and the tech is trying to advise me to buy a straight cool unit with heat strips vs a heat pump. He's telling me that the average temperature there would not warrant a heat pump and I would benefit from the lesser priced straight cool, which also has a higher SEER rating. I'm not 100% sold..so I wanted some others thoughts.
ArmyChief is offline   Reply With Quote
Old 04-04-2013, 11:25 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
electric heat is the most expensive heat there is, at least with a heat pump you're using the refrigerant that is in the system to heat your home. unless that refrigerant leaks out that is yours, paid for once. All you pay for is the motors running.
how often or how many weeks or months a year do you use heat? How often during that period did you need secondary (emergency) heat to assist the heat pump?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-04-2013, 11:33 PM   #3
Doc,
According to the HVAC guy..the number of days that heat would be needed..and using the heat strip (COP of 1), would be offset and more by the increased efficiency of the longer A/C season.
Old 04-05-2013, 01:08 AM   #4
[XLS]
Heating Fuel Comparision Calculator - EIA
http://www.eia.gov/electricity/month...?t=epmt_5_06_a
http://www.warmair.com/html/fuel_cost_comparisons.htm
I posted a graph once on this site but I can't seem to find it now, but electricity is approximately 3x's as expensive than other heating fuels.
All systems have a seer rating, if you get a high enough one you can cut down on the electrical consumption as motors use less energy but not your electric rate that you pay from your service provider.
Thanks.
Old 04-05-2013, 04:38 AM   #5
An old Tradesmen
Rewards Points: 7,412
Stay with a heat pump. Electric resistance heat only will cost you as much as 3 times more to heat your home.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (04-06-2013)
Old 04-05-2013, 08:08 AM   #6
Rewards Points: 242
sounds like the guy is trying to steer you away from a heat pump.
maybe he dosent like to install them. ask him how many he has installed.
get 3 quotes.
stay with the heat pump.
hvac instructor is offline   Reply With Quote
The Following User Says Thank You to hvac instructor For This Useful Post:
Old 04-05-2013, 11:01 AM   #7
Rewards Points: 484
Stay with heat pump and if your contractor doesnt like them, find one that does. The price difference between buying a heat pump versus a straight cool unit is very small, you will make up for that in heat savings quite fast.
sammy37 is offline   Reply With Quote
Old 04-05-2013, 11:27 AM   #8
Special User
Rewards Points: 1,230
OP, you have to run the calculations. The straight A/C has a higher SEER, meaning you will save money on your summer cooling bill. Say the straight-A/C summer savings are $100/yr and the winter expenses of strip heat are an extra $75/yr: you'd come out $25 ahead with straight A/C. Not to mention the lower cost of installation.
But maybe the straight A/C only saves $50 per summer and the winter strip heat costs an extra $200 per winter, so you lose. Without running the numbers, there's no way to tell which way you should go. I recommend using this:
www.eia.gov/neic/experts/heatcalc.xls
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Electric baseboard VS Heat pump Mattme123 HVAC 20 09-21-2012 08:41 PM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
Replacing thermostat, no heat (heat pump, 2 stage heat, 1 stage cool) BrianJM HVAC 20 09-28-2011 09:53 AM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 03:23 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
