Heat Pump Vs In Floor Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2010, 07:47 PM   #1
Heat pump vs in floor heat
What is more efficient a heat pump or in floor heat with electric boiler.
I'm building a new house and the main floor has 1500 sq feet and the basement has the same. It will also have a 24X24 attached garage. I'm putting in in-floor heat and will also put a heat pump primarily for the AC. I definitely want the in-floor for the comfort. That being said I was under the impression that heat pumps are more efficient. If this is true would it be more efficient to run the in-floor at low. Just enough to get the floor warm and then bring up the rest with the heat pump. Or will the fact that I would be running 2 units(heat pump and boiler) defeat the purpose.
mugen is offline   Reply With Quote
Old 03-01-2010, 11:15 PM   #2
An old Tradesmen
Rewards Points: 6,928
Depends how well you insulate the slab. using electric. I hope at least 2" under the slab, and as much as you can get on the perimeter.
Old 03-02-2010, 05:09 AM   #3
2" under slab and foam insulation in the walls
Old 03-02-2010, 05:11 AM   #4
An old Tradesmen
Don't forget the perimeter insulation for the slab. or you'll pay the price for years to come.
Old 03-02-2010, 09:56 AM   #5
There are heat pumps out there that can heat water for radiant floors. You didn't mention ground-source heat pumps, but we're looking at a Waterfurnace Synergy that has forced air heating and cooling, and can also heat water for radiant. I'd bet there are others out there...
houseinthewoods is offline   Reply With Quote
Old 03-02-2010, 08:18 PM   #6
I will not be going with a water source heat pump. So it will just be a regular heat pump and a boiler. Also yes I will insulate the perimeter of the slab.
infinity heat pump always on aux heat below 40 degree hirrlinger HVAC 4 07-18-2010 12:51 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 06:12 PM
Heat pump problem, indoor fan blows in heat but not A/C or "on" lngroller HVAC 2 06-03-2009 07:55 AM
Ductless Heat Pump for Garage?? brittlediabetic HVAC 25 04-23-2009 02:28 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 02:02 PM
