-   -   Heat pump vs in floor heat (http://www.diychatroom.com/f17/heat-pump-vs-floor-heat-65750/)
mugen 03-01-2010 07:47 PM
What is more efficient a heat pump or in floor heat with electric boiler.
I'm building a new house and the main floor has 1500 sq feet and the basement has the same. It will also have a 24X24 attached garage. I'm putting in in-floor heat and will also put a heat pump primarily for the AC. I definitely want the in-floor for the comfort. That being said I was under the impression that heat pumps are more efficient. If this is true would it be more efficient to run the in-floor at low. Just enough to get the floor warm and then bring up the rest with the heat pump. Or will the fact that I would be running 2 units(heat pump and boiler) defeat the purpose.
beenthere 03-01-2010 11:15 PM
Depends how well you insulate the slab. using electric. I hope at least 2" under the slab, and as much as you can get on the perimeter.
mugen 03-02-2010 05:09 AM
2" under slab and foam insulation in the walls
beenthere 03-02-2010 05:11 AM
Don't forget the perimeter insulation for the slab. or you'll pay the price for years to come.
http://resourcecenter.pnl.gov/cocoon...inline/515.jpg
houseinthewoods 03-02-2010 09:56 AM
There are heat pumps out there that can heat water for radiant floors. You didn't mention ground-source heat pumps, but we're looking at a Waterfurnace Synergy that has forced air heating and cooling, and can also heat water for radiant. I'd bet there are others out there...
mugen 03-02-2010 08:18 PM
I will not be going with a water source heat pump. So it will just be a regular heat pump and a boiler. Also yes I will insulate the perimeter of the slab.
