Old 06-30-2009, 10:45 PM   #1
Default heat pump VS electric air handler
What is the difference be heating with heat pump VS electric air handler?
Located in nc. Doe they work the same with termostat?
V Moe is offline   Reply With Quote
Old 06-30-2009, 11:20 PM   #2
Yoyizit's Avatar
~3x higher heating elec. bill with all-elec. heat?
More On This Topic
Hi, my name is Mark Delgado with American Auto Service for Expert Village. You'll have high pressure in the high side when you have restrictions also. That may mean that in the orifice tube, if the compressor is starting to put debris into the system, it... Read More »
Hi my name is Mark Delgado with American Auto Service for Expert Village. When the high pressure refrigerant leaves the compressor it will leave the compressor through a line. This is a manifold line assembly. It will be the high pressure side as the... Read More »
Hi my name is Mark Delgado with American Auto Service for Expert Village. The reason I chose this 97 Nissan Pickup was because the compressor is visible and some of the other components are just as visible. To understand the basic airconditioning system... Read More »
Hi my name is Mark Delgado with American Auto Service for expert Village. Once in the evaporator coil it will obsorb the heat from the interior of the vehicle. Because the evaporator coil is deep inside the dash I just want to show an example of what it... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. So we have the compressor that compressed the refrigerant to a high pressure gas that went through the line. Now it goes through the condenser. In this condensor unit, it's like a... Read More »
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 05:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 09:37 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 12:28 PM
Honeywell VisionPro and Carrier heat pump ERE HVAC 0 08-07-2008 09:36 AM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 04:02 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
