Heat Pump Vs Aux Electric Heat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-05-2008, 08:45 PM   #16
Originally Posted by batolson View Post
Below are the instructions, what numbers would you choose assuming my current settings are as recommended:
0240
First stage heat cycle rate (CPH= cycles per hour)
5 Gas or oil furnaces of less than 90% efficiency
1 Steam or gravity systems
3 Hot water systems & furnaces of 90%+ efficiency
9 Electric furnaces
[Other options: 2, 4, 6, 7, 8, 10, 11, 12 CPH]
0250
Second stage heat cycle rate (CPH)
3
9 Electric furnaces
0260
Third stage heat cycle rate (CPH)
9 Electric auxiliary heat or electric furnaces
3
0270
Emergency heatcycle rate (CPH)
9 Electric emergency heat
3
I finally checked the current settings and was suprised to find that I did not have option 0240 or 0250 available to program even though an earlier option indicated the thermostat was set for a 3 heat cycle 2 A/C cycle system. My thermostat is a Honeywell TH8320u10008. Wired with red jumpered to R&RC, Orange to O/B, Yellow to Y, Green to G, Blue to C, Black to Y2, White to Aux which is jumpered to E.
batolson is offline   Reply With Quote
Old 01-17-2009, 10:28 AM   #17
jdv
Heat Pump question
Just moved from Florida to North Carolina. House has two heat pump units 2.5 ton each and total sq ft. is 2900. Two story home. House has one Trane that operates biggest part of the house and carrier upstairs. No nothing about heat pumps since Florida is so warm. Concerned that not operating correctly or settings are incorrect as the systems seem to never shut off.
jdv is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Better for heat pump or electric coil/strip? Lori 48616 HVAC 5 09-05-2008 02:28 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 02:02 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
