Heat Pump Tstat Install - HVAC - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 04:45 PM   #1
heat pump tstat install
I'm trying to switch my old trane stat to a new honeywell stat. i think I've got it figured out but i don't know where to put the 't' wire in the new stat. i believe it controls the thermistor. please help.
old stat: new stat:
red-r c-blue
tan-t
orange-o o/b-orange
green-g g-green
yellow-y y-yellow
white-x2 to u e-white
blue-b c-blue
l-open
aux=open
belanger44 is offline   Reply With Quote
Old 08-04-2012, 04:53 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
aux needs jumpered to E. Tan is taped off and not used.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-04-2012, 04:58 PM   #3
why is 't' tape off. it is connected in the condenser outside.
Old 08-04-2012, 05:01 PM   #4
AKA HVACTECHFW
the honeywell thermostat does not use it.
IT IS WHAT IT IS
Old 08-04-2012, 05:03 PM   #5
will it effect the heat pump in any way? performance?
Old 08-04-2012, 05:04 PM   #6
does the 't' wire control the thermistor?
Old 08-04-2012, 05:07 PM   #7
AKA HVACTECHFW
T sent a signal to the old t-stat for temp. It is not necessary for the new thermostat. It really doesn't matter what it did. It was only for proprietary thermostats from trane.
IT IS WHAT IT IS
Old 08-04-2012, 05:19 PM   #8
thank you for our help
Old 08-04-2012, 07:08 PM   #9
the t terminal is only required for that trane tstat. it was used for the heat anticipator. that stat needed the t input. the honeywell does not.
turnermech is offline   Reply With Quote
What did I do? Heat Pump isn't working ChrisDIY HVAC 10 03-14-2011 04:55 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
