-   -   heat pump tstat install (http://www.diychatroom.com/f17/heat-pump-tstat-install-152604/)
belanger44 08-04-2012 04:45 PM
I'm trying to switch my old trane stat to a new honeywell stat. i think I've got it figured out but i don't know where to put the 't' wire in the new stat. i believe it controls the thermistor. please help.
old stat: new stat:
red-r c-blue
tan-t
orange-o o/b-orange
green-g g-green
yellow-y y-yellow
white-x2 to u e-white
blue-b c-blue
l-open
aux=open
hvactech126 08-04-2012 04:53 PM
aux needs jumpered to E. Tan is taped off and not used.
belanger44 08-04-2012 04:58 PM
why is 't' tape off. it is connected in the condenser outside.
hvactech126 08-04-2012 05:01 PM
the honeywell thermostat does not use it.
belanger44 08-04-2012 05:03 PM
will it effect the heat pump in any way? performance?
belanger44 08-04-2012 05:04 PM
does the 't' wire control the thermistor?
hvactech126 08-04-2012 05:07 PM
T sent a signal to the old t-stat for temp. It is not necessary for the new thermostat. It really doesn't matter what it did. It was only for proprietary thermostats from trane.
belanger44 08-04-2012 05:19 PM
thank you for our help
turnermech 08-04-2012 07:08 PM
the t terminal is only required for that trane tstat. it was used for the heat anticipator. that stat needed the t input. the honeywell does not.
