Heat Pump trips breaker
ya mr hvac that does happen.The system could have had some start up issues.Possibly drawing high amps trying to fire up.I always ck out electrical connections to make sure good and tight.Also if system has aluminum wires feeding it ,Make sure to put de-ox compound on the connections.Helps it stay cool and dont oxidize the electrical connection. Sometimes when ther systems running and goes into a defrost ,the system may not terminate defrost quick enough and cause it to trip as well.This is an outside possibility to. From your post it doesnt sound to bad !
