Heat Pump Thermostat Wiring - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 10:34 PM   #16
AKA HVACTECHFW
Rewards Points: 1,208
RED - Rc JUMPERED TO R
ORANGE - O/B
YELLOW - Y
GREEN - G
WHITE - Aux
BROWN - E
NOT USED - L
BLUE - C
I don't like this setup because you don't get full tempering during defrost cycle and Never get full heat during call for aux heating. You can jumper AUX to E to get full heat, however, then your always using more energy when aux heat is called for. A better stat to allow the system to function with full potential would be the honeywell IAQ. Also, one note is that I don't recommend setback temps on a heat pump system because it will cause the electric heat strips to come on and offset any savings you might have seen from using setback temps. HP systems are set and forget it.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-14-2011, 10:36 PM   #17
AUX and E are the same terminal
SHBicycle is offline   Reply With Quote
Old 03-14-2011, 10:42 PM   #18
I'm Your Huckleberry
Rewards Points: 2,270
Please don't shoot yourself, I just found that comment funny.
Doc Holliday is offline   Reply With Quote
Old 03-14-2011, 10:53 PM   #19
AKA HVACTECHFW
Both white and brown would go to this terminal. Again this is not providing you full potential and comfort your system can offer. Connecting it this way will work to get you going though. The other thing you could do is WHITE to AUX/E and BROWN to L. This thermostat has full output on L when put in emergency heat.
IT IS WHAT IT IS
Old 03-14-2011, 11:08 PM   #20
what would be a good thermostat for this heat pump?
Old 03-14-2011, 11:09 PM   #21
AKA HVACTECHFW
Honeywell IAQ
IT IS WHAT IT IS
Old 03-15-2011, 05:07 AM   #22
An old Tradesmen
Rewards Points: 6,132
The TH6320 is a 3 stage heat pump thermostat. However, it is designed to control 2 stages of heat pump and 1 stage of aux heat. The YTH9421 is a much better thermostat, and will stage in both the compressor and aux heat. As its a 4 stage thermostat.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (03-15-2011)
Old 03-15-2011, 06:19 AM   #23
I like aprilaire 8466
heatycooly is offline   Reply With Quote
Old 03-15-2011, 03:28 PM   #24
An old Tradesmen
Seen a few, but never really used them myself. I've heard good things about them though. I think Honeywell even copied a feature or 2 from Aprilaire on some of their thermostats.
carrier infinity 50Xt packaged heat pump with infinity thermostat mguillen HVAC 12 12-05-2011 02:42 PM
Thermostat Heat Pump Wiring difficulties akg4y HVAC 8 04-15-2010 06:16 AM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 03:26 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 01:54 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
