Heat Pump Thermostat Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 12:25 AM   #1
Heat Pump thermostat wiring
Old thermostat used W2, Y, and O. All other wired are the same.
New thermostat has W1, W2, Y1, Y2 and O/B
I match the wire W2-W2, Y-Y1 (stage 1 cooling) and O to O/B.
The question is when I mount the wire O to O/B, it has the setting option in the new thermostat:
O/B terminal is energized for reversing valve in cooling.
O/B terminal is energized for reversing valve in heating.
Which one should I set it at?
max2k is offline   Reply With Quote
Old 10-07-2010, 04:11 AM   #2
An old Tradesmen
Rewards Points: 7,816
Reverse in cooling.
Unless your unit is a Rheem or Rudd.
Old 10-07-2010, 08:04 AM   #3
Thanks a lot for your help beenthere, I really appreciate it.
Old 10-12-2010, 01:27 PM   #4
Rewards Points: 95
Originally Posted by beenthere View Post
Reverse in cooling.
I'm curious why Rheem/RUUD does it the other way.
garya505 is offline   Reply With Quote
Old 10-12-2010, 03:06 PM   #5
An old Tradesmen
Don't know.
Funny thing is. On some of their commercial units. They energize it in cooling like everyone else.
Old 10-12-2010, 03:42 PM   #6
Rewards Points: 95
Don't know.
I guess the only diff is, if you have a heat pump and you just want to cool with it, with most of them you could just jumper Y to O and it would never go to heating mode.
Thermostat Heat Pump Wiring difficulties akg4y HVAC 8 04-15-2010 05:16 AM
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 06:32 PM
changed thermostat on York Affinity, now no heat? sotwell HVAC 1 03-01-2009 05:34 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Luxaire heat pump wiring diagram StevieRay HVAC 5 07-02-2008 10:08 AM
