Heat Pump Thermostat HELP!!! - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 09:30 AM   #16
Was told they are sequencers. Not likely to have messed them up. I tripped the circuit breaker back and forth a few times. Seemed to be working properly. Still not call for Aux heat. Was also told this was a 10kw unit that is 2 stage but calls for all ten kw at the same time. I guess that would explain both the white and Brown wires... They both end up at this heater but are jumped together at the unit.
MichaelG is offline   Reply With Quote
Old 12-08-2010, 10:13 AM   #17
Still no secondary heat kicking in....
Old 12-08-2010, 10:26 AM   #18
Rewards Points: 392
Originally Posted by MichaelG View Post
Wow the morbid death and decay!
zootjeff is offline   Reply With Quote
Old 12-08-2010, 12:49 PM   #19
Are those transformers? Can I just swap it out?
That is a sequencer you can replace. Could you see the element inside
Hixheat1 is offline   Reply With Quote
Old 12-08-2010, 05:15 PM   #20
An old Tradesmen
Rewards Points: 8,192
Looks more like dead mice then transformers.
Follow the yellow wires. One will go to the power feed. The other to the strip heater, or its fusible link.
Old 12-09-2010, 07:31 AM   #21
thanks!
Thank you all for the help! I broke down and got a service tech. Best $80 I ever spent. It was low on Freon and he fixed the secondary heat. My house is now a toasty 68 degrees. He did however let me know that my unit was a 2 ton and I really could use a 3 ton. 1500 sq ft and 14ft ceilings throughout about half of it.
Old 12-09-2010, 07:39 AM   #22
two guys electrocuted--shorted out system
after repairing this plug up the hole with something they won't eat!!
Not transformers-- limits and controls.
You need a professional at this point for quicker repair.
Artco is offline   Reply With Quote
Old 12-09-2010, 04:50 PM   #23
An old Tradesmen
Doubt you need a 3 ton.
How well has it cooled in previous years.
How well has it heated in previous years.
Hunter Thermostat Model 44860 Heat Pump Emergency Heat Does Not Work On Auto stvnhdmpa HVAC 8 12-08-2010 05:44 PM
Setting heat pump with oil back up thermostat sandy_d HVAC 0 11-06-2010 07:53 AM
Heat Pump thermostat wiring max2k HVAC 5 10-12-2010 03:42 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 12:54 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
