Heat Pump Thermostat Emergency Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 12-10-2009, 03:36 AM   #1
Heat pump thermostat emergency switch
I have a Trane Weathertron (BAYSTAT240A) thermostat for my Trane heat pump. When the outside temp is nears 35 degrees the heat pump struggles. There is an Emergency "On" switch which I guess turns on the electric auxiliary coils and disables the heat pump. If that is accurate, does the cost of operation increase substantially? In normal operation around 35 degrees, the unit seems to run most of the time--a five minute break per 20 minutes of operation. Is the efficiency of the emergency heat greater than this almost full time running in heat pump mode?
Thanks!
joe913 is offline   Reply With Quote
Old 12-10-2009, 05:06 AM   #2
An old Tradesmen
Rewards Points: 7,746
No it isn't.
At 35 the heat pump is supplying you with heat for a about 1/3 to 1/2 the cost of what the emergency electric heaters would.
If its running 20 minutes and shutting off for 5 minutes. Its at just under 3 cycles per hour. Which is fine for 35 outdoor temp.
Old 12-10-2009, 12:54 PM   #3
Thank you very much. I bought this home with the AHAC heat pump in place without an owners guide or manual for the operation. Your help is appreciated.
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Heat pump problem, indoor fan blows in heat but not A/C or "on" lngroller HVAC 2 06-03-2009 07:55 AM
Heat pump circuit breaker pbms pinkertonpv HVAC 11 02-18-2009 09:47 AM
Heat Pump czars HVAC 3 02-06-2009 08:49 PM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 10:02 AM
