Heat Pump Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 09:32 PM   #1
Cool
heat pump thermostat
  1. How to wire a Honeywell thermostat to a Rheem heat pump with aux heat?
mileswi is offline   Reply With Quote
Old 10-08-2011, 10:02 PM   #2
Houston204's Avatar
Rewards Points: 556
Turn off power to the indoor unit. This may be more than 1 breaker.
Write down the terminal = wire combination in use with the old stat.
Wire the new multistage heat pump stat using the same color code that the old stat used.
Restore power and configure for heatpump operation with electric strips if this is what you have.. (option 170 = 7 with many models)
Configure the O/B terminal to be B energize to heat. (option 190 = 1 with many models)
Houston204 is offline   Reply With Quote
Old 10-08-2011, 10:39 PM   #3
Rewards Points: 268
I will add, Honeywell has very specific instructions for each model. You may want to give that model number.
JackDidley is offline   Reply With Quote
Old 10-08-2011, 10:56 PM   #4
Rewards Points: 6,652
Read the directions.
Heat Pump Thermostat wiring SHBicycle HVAC 23 03-15-2011 03:28 PM
What did I do? Heat Pump isn't working ChrisDIY HVAC 10 03-14-2011 04:55 PM
Hunter Thermostat Model 44860 Heat Pump Emergency Heat Does Not Work On Auto stvnhdmpa HVAC 8 12-08-2010 06:44 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 01:54 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
