Heat Pump T Stat Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 03:54 PM   #1
Rewards Points: 16
Daughter ccalled and said the Tstat was displaying a "flame and snowflake".
From what google told me its in lockout mode. Is something going on that I should call a tech out?
Thanks,
Ed
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 07-05-2013, 05:31 PM   #2
An old Tradesmen
Rewards Points: 6,132
Probably. can't tell you much with the limited info. I would reset it once, and see what it does.
Old 07-05-2013, 05:38 PM   #3
Rewards Points: 16
What more do you want? Are you talking pressures or equipment?
Old 07-05-2013, 05:47 PM   #4
An old Tradesmen
Brand and model number of tstat. Same for equipment.
While line pressures and temps would help. I figured you didn't have them to post.
Old 07-05-2013, 06:00 PM   #5
Rewards Points: 16
York 8 yrs old +/_
Air Handler: F2FP048H06BS/XNMS309199
Heat Pump: E1RC042S06D
Stat: Getting information
Old 07-05-2013, 06:17 PM   #6
Rewards Points: 16
White Rodgers 1F89-211
Old 07-05-2013, 06:27 PM   #7
An old Tradesmen
If its flashing, its in lock out to prevent the compressor from short cycling.
If its not flashing. turn off the power to the indoor unit for a minute. then turn back on. If snowflake and flame come back on and are not flashing. Time for a new stat.
PS: If its powered by batteries, change them.
The Following User Says Thank You to beenthere For This Useful Post:
digitalplumber (07-05-2013)
Lennox Heat Pump no_limit_larry HVAC 4 11-05-2012 06:18 PM
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 08:07 AM
Heat Pump Crisis Part II Doc Holliday HVAC 58 12-07-2011 10:14 PM
heat pump / BTU question jwalker95 HVAC 3 12-07-2009 07:40 AM
Easy Heat Pump Question brutis HVAC 6 11-03-2008 11:06 AM
