Heat Pump System Is Heating When On Cool Setting Every 3-4 Days???? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 11:00 AM   #1
heat pump system is heating when on cool setting every 3-4 days????
Can anyone tell me why we get hot air ( the heat strip comes on ) every 2-4 days when the air conditioner is running?
The outside unit is running and the heat strip is running. I can shut it off at the thermostate and turn it back to cool after 15 minute and it works Ok for 2-4 days.
I installed a new thermostrste but it still malfunctions. The system is 3 years old.
tommy56 is offline   Reply With Quote
Old 08-08-2011, 05:16 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
sounds like you may have a outdoor thermostat on the system that is malfunctioning or you have short in the low voltage wiring somewhere.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
tommy56 (08-09-2011)
Old 08-08-2011, 06:46 PM   #3
Rewards Points: 392
What is the:
Make and model number on the outdoor unit?
Make and model of the thermostat?
Rough explanation of low voltage wiring, can you map it out for us?
zootjeff is offline   Reply With Quote
The Following User Says Thank You to zootjeff For This Useful Post:
Old 08-08-2011, 09:04 PM   #4
Could be a faulty defrost board. Disconnect the wire on the E and W2 terminals of thermostat. And the defrost em heat wire on the defrost control on the outdoor unit. Give us a model/manufacturer of system.
If you disconnect these wires and the heat still comes on then its time to call the a/c guy to chase down the shorted wire.
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
Old 08-09-2011, 07:24 AM   #5
Model Numbers
Originally Posted by zootjeff View Post
What is the:
Outdoor unit Goodman Model No. GSH130481AD
Thermostat Lux Pro Model No PSH521L
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Installing a New Central Air System vdu HVAC 7 09-01-2009 03:45 PM
Changing my heating system, need advice sethfc HVAC 4 08-10-2009 09:46 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Heat Pump + Aux Heat Problem - Can You Help? whitedavidp HVAC 17 12-25-2008 06:37 PM
