Heat Pump To Supplement Oil? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 09:15 AM   #1
Custom User Title
Rewards Points: 252
Heat Pump to supplement Oil?
We are currently receiving quotes to get an AC Condenser installed at our house. We already have the duct work and the blower as we have forced air oil heat. Some of the options that we are being given include a heat pump. They say that we set it up so it comes on instead of the oil until it gets down to 40 degrees (or whatever we decide). This allegedly reduces the amount of oil we will use in a year. My question is, how much extra electricity does it use instead? Is there a way to see how much of a difference there will be? It is tempting as the heat pump only costs about $350 more but I don't want to find out that it will actually cost us more down the road.
Thoughts?
no1hustler is offline   Reply With Quote
Old 04-24-2013, 11:25 AM   #2
Special User
Rewards Points: 1,230
Only down to 40F degrees is a pretty crummy heat pump. Modern heat pumps should be able to operate down to 20F or even lower.
It uses about the same as central A/C.
You may find this comparison spreadsheet useful: www.eia.gov/neic/experts/heatcalc.xls . It can't estimate what your bill will be since the size of your house, insulation, and local weather are variables, but the sheet will let you compare the cost of oil to the cost of an air source heat pump to see if it's cheaper or more expensive based on your oil and electricity prices.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
no1hustler (04-24-2013)
Old 04-24-2013, 12:20 PM   #3
Custom User Title
Rewards Points: 252
The unit priced was a Trane. The person said 40 degrees or whatever you decide on so I don't know if 40 is the limit by any means.
Old 04-24-2013, 03:31 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
The balance point is where you put it at. Most contractors leave it up higher to reduce call backs for complaints of "its blowing cold air". Heat pumps put out no where near the amount of heat that an oil furnace does. Having said that, I would absolutely get a heat pump over a straight a/c in your case.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-24-2013, 05:01 PM   #5
An old Tradesmen
Rewards Points: 6,480
The heat pump at about 35 degrees and warmer will cost about 1/3 of what the oil would cost to use to heat your house.
Lennox Heat Pump no_limit_larry HVAC 4 11-05-2012 06:18 PM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 09:07 AM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
