Heat Pump Superheat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2013, 12:00 PM   #1
heat pump superheat
I installed a Mitsubishi mini split system. In the heating mode (Emergency heat), the gas line temperature at the compressor is about 90F. This should be much higher, right?
Thanks for your help.
Ron
rwfegley is offline   Reply With Quote
Old 12-19-2013, 01:55 PM   #2
Rewards Points: 154
mini-splits
On the mini-splits, the charge should be weighed into the system if any additional charge is needed. This will be determined by the length of the piping, not the charge or how hot it feels to the touch.
Patrick Eubanks is offline   Reply With Quote
Lennox Heat Pump no_limit_larry HVAC 4 11-05-2012 05:18 PM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 08:07 AM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
