Heat Pump Runs All The Time - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 07:32 PM   #1
Heat Pump Runs all the time
I'm in the process of buying a house. On the home inspection the inspector discovered that the upstairs heat pump would not shut off even with the thermostat set to off. It is a split all electric unit with the air handler in the attic. The house and units are approx 12 years old. The thermostat has to somewhat still work because it shuts the air handler off and on properly, and it still heats the upstairs except the outside fan never shuts off unless you flip the breaker. We are buying the home at such a low price the sellers are unable to do any repairs, so I'm just trying to get an idea of what I'm going to be facing once we move in. Thanks for any info!
kirb62 is offline   Reply With Quote
Old 12-05-2012, 08:19 PM   #2
JJboy's Avatar
Check the contactor low voltage. If the fan is running probably the compressor is running too.....
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 12-06-2012, 04:32 AM   #3
An old Tradesmen
Rewards Points: 7,372
Could be a short in the thermostat wires, or it could be a stuck/burnt fast contactor.
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 08:07 AM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Heat pump vs. Radiators - Opinions/Recommendations rflail HVAC 7 11-10-2010 09:56 PM
Heat pump aux heat runs (almost) always snappjay HVAC 10 01-27-2010 07:49 AM
