Heat Pump R410A Pressures - HVAC - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 05:18 AM   #1
Heat pump R410A pressures
I am an old school HVAC tech. trained in R-12 and 22. I have two new Goodman systems installed by 'Who knows?' Systems were installed before cient bought forclosed home. All the low voltage wiring was a disaster. (Obviously done by someone who didnot know what they were doing). One system is R-22 and the other is R-410A. The 410 A system is not operating properly. I put guages on it (the new type for 410A) and the pressueres read 35psi on the low side and 100psi on the high side. Suction line is sweating. Is this anywhere near normal? I thought 410 systems ran higher pressures than 22. I have no temperature drop across inside coil, any suggestions.
lgmbroker8 is offline   Reply With Quote
Old 03-21-2012, 07:23 AM   #2
100 head= 37 degree saturation temp
35 suction = a negative 11 saturation temp
Can't have sweat at 11 below zero F so my guess is it's not 410A in there. Kind of looks like pressure readings for 134a. Reclaim,leak check,vacuum to 500 microns then charge with fresh 410A.
Old 03-21-2012, 08:41 AM   #3
Rewards Points: 380
Looks like you are out of gas, follow marty's advice and recover, pressure test, and repair then recharge system using subcooling method.
HVACDave is offline   Reply With Quote
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
