Heat Pump Question/moved From Florida - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 12:11 PM   #1
jdv
heat pump question/moved from Florida
Just moved from Florida to North Carolina. House has two heat pump units 2.5 ton each and total sq ft. is 2900. Two story home. House has one Trane that operates biggest part of the house and carrier upstairs. No nothing about heat pumps since Florida is so warm. Concerned that not operating correctly or settings are incorrect as the systems seem to never shut off.
jdv is offline   Reply With Quote
Old 01-17-2009, 12:18 PM   #2
staying warm
heatpumps are great around 50 degs and above. as temps drop they get less effecient. when you hit 38 deg the absorption rate is very low.
reason for 2.5 ton units on such a big house is you have low cooling load and don't need much, you would need about 2 4 ton units for heating that much area at nc temps, I own a house in nc also and live in florida. I use gas for heat and do not even have ac at cabin yet. one day I will put one int but it will be 2 ton ac and gas heat. Also better consider backup generator there also!! Wood heater is nice also! don't have to have power to stay warm with wood heater.
Alien
ALiEnDuDe is offline   Reply With Quote
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
Florida heat pump -- no heat mverrill HVAC 3 11-06-2007 11:08 AM
