Old 07-12-2005, 04:02 AM   #1
Heat pump problem
Last week I noticed my inside fan was not cutting off and the air it was blowing was not cool. I also noticed the outside unit was not running. I called a friend who used to do HVAC work and he told me it was the contactor. I replaced it and everything works fine until nightfall and then the outside unit will not start up. I have tried but not detected any sounds from the outside unit when this occurs. I will turn the system off and then when I restart it the next day it works fine again until nightfall. I have also changed the thermostat thinking that might have contributed to the problem. Anyone have any thoughts on the situation. I am hesitant about calling a service tech after being gouged by one a couple of years ago.
trprider is offline   Reply With Quote
Old 07-22-2005, 12:15 AM   #2
Heat pump problem
what did you replace???program your temps right???a fan will continue to run ,to circulate air after the temp is reached ,for a while..on certain makes
murray is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
heat pump dreck HVAC 2 09-11-2006 08:18 PM
heat pump not working kyleGR HVAC 2 05-30-2006 03:35 PM
