Old 02-23-2010, 06:53 PM   #16
Still going...
ChrisDIY's Avatar
Heat Pump, is it performing within spec?
While working on the additional return into closet I noticed that when the unit reversed I hear a lot of gurgling and swishing. Is this a sign I am under-filled on refrigerant?
--Chris
ChrisDIY is offline   Reply With Quote
Old 02-23-2010, 07:07 PM   #17
An old Tradesmen
--Chris
No, its common.
Old 04-01-2010, 01:56 PM   #18
Still going...
ChrisDIY's Avatar
Short of doing a Manual J is there any "test" to determine if unit is properly sized? I know every house is different. The North half has a Century RSC1230 which I believe is a 2.5 ton. If I replace 1 for 1 I'm stuck at 15 SEER. What will happen going to a 3 ton 18 SEER?
When we took possession we only ran unit in cooling mode maybe a month and I cannot remember how it performed.
--Chris the DIY Guy
Still going, on Ibuprofen...
Old 04-01-2010, 04:03 PM   #19
An old Tradesmen
Wait for one of your hottest days and see if it runs continuous, or cycles on and off. If it cycles on and off, its over sized.
Best thing to do is a load calc. And see what size you need.
An over sized unit on under sized duct work can make a lot of noise.
Old 04-01-2010, 04:36 PM   #20
Still going...
ChrisDIY's Avatar
Argh! I'm kinda stuck beyond that. It was disconnected last fall for the hydronic air-handler and is R-22. Everything to be installed is the R410A. The unit that is still running is the one we were talking about originally. It's a 3 ton and I will see how it runs in late July.
My HVAC guy has taken ill and I am trying to do this on my own and I'm not an HVAC contractor.
--Chris the DIY Guy
infinity heat pump always on aux heat below 40 degree hirrlinger HVAC 4 07-18-2010 01:51 PM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 03:26 PM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 10:46 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Heat pump problem, indoor fan blows in heat but not A/C or "on" lngroller HVAC 2 06-03-2009 08:55 AM
