Heat Pump In PA - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-30-2012, 02:54 PM   #16
An old Tradesmen
Rewards Points: 8,142
Probably incorrect charge. Slightly low will cause the air to be cooler then it should be. Also, air flow may be set too high. Its a good heat pump. York/Luxaire/Coleman/UPG.
Old 10-30-2012, 03:00 PM   #17
can I ask how many runs that size home and system should have? and what should I typically pay for a recharge of the system? just so i dont get hood winked locally. Is it normal for the thing to run almost non stop.....if its in the lower 50;s or upper 40s it runs normal...but soon as we drop lower...it runs and runs.....maybe the charge will help this too
mopardude is offline   Reply With Quote
Old 10-30-2012, 03:05 PM   #18
An old Tradesmen
Its more how much air the runs put out in total, then the number of runs. I have some 2 ton package units with only 2 supplies. Each supply outs out 425 CFM. Your 2 ton should be moving 800CFM.
Prices vary by the company, and by the area, so no one set price for a recharge/top off.
Old 10-30-2012, 03:16 PM   #19
when u say 2 supplies.....please elaborate........when u say this it make me think the number of lines running from the outdoor unit too the air handler?.......I believe I only have one larger line running up the side of the house into the attic.......but maybe this isnt what Your talkin about
okay i just re read ur post....i get it....u meant heat vents.....must be a small house if it only has two supplies?
Old 10-30-2012, 03:47 PM   #20
An old Tradesmen
Sound studio.
Old 10-31-2012, 01:54 PM   #21
could u please give me a ballpark for the service though...just a range...so i dont get smacked....I have no idea...is this a 100 dollar service? 200 300 ect......thank you!
Old 10-31-2012, 05:00 PM   #22
An old Tradesmen
Can't give you a price for your area. I get 125 bucks to come out and tell someone whats wrong with their unit. Thats no repair yet. I'm flat rate, so my prices may be higher then what your many in your area charge.
Old 11-01-2012, 12:16 PM   #23
okay thanks....just wondering what a service call with a freon check and or recharge approx runs.....thanks for the help.
Old 11-01-2012, 03:22 PM   #24
An old Tradesmen
Varies from $$ to $$$.
Old 11-01-2012, 04:59 PM   #25
Is the air flow controlled by the air handler im assuming?
Old 11-01-2012, 06:57 PM   #26
An old Tradesmen
By air handle, and how well the duct was sized.
Old 11-02-2012, 08:13 AM   #27
somehting I noticed on our system...when the its de-icing its self.....the fan continues to run and blow cold air....It would make more sense to me..that when its in that mode the fan would automatically shut down until its defrosted......make sense? or is this normal.
Old 11-02-2012, 05:47 PM   #28
An old Tradesmen
The indoor fan should stay running and aux heat should come on to temper the air. The outdoor fan should shut off.
Old 11-03-2012, 08:32 AM   #29
okay...see we do not have the heat strips...so its probably working fine.....yes the outdoor unit does shut off..while its de iceing.....but the airhandler fan continues to blow.......and with out a secondary heat source of course its goin to blow colder air while the system is down....do u know of any way to change that as to we dont have the heat strips? so the air h fan does stop? We run a pellots stove in teh colder month...end of nov through beginnnin of march.....its sit below our air intake of the heat pump system in our living room.....while the heat radiates off the stove below the air intake duct....we then sometime keep the systems fan running...so it distributes some of the warmer air through out the home, its a crude system but it being a stacked cape cod thats relatively small...its works decent. That was the installers idea by the way..lol
Old 11-03-2012, 12:56 PM   #30
An old Tradesmen
The blower can be shut off during defrost by adding a relay. weather or not it will harm the heat pump is up in the air. Along with it could cause much longer defrost cycles.
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 08:07 AM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
