Heat Pump Outside Unit Not Working - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 08:40 AM   #16
Part of the Clover Leaf
Originally Posted by dosy777 View Post
I am especially fond of the newer lennox HP's because they can be solar powered......
http://www.lennox.com/products/heat-pumps/XP21/
Wow! One solar panel powers the entire heat pump process?
I gota buy me two of them bad boys.....
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
hvactech126 (02-11-2012)
Old 02-11-2012, 10:57 AM   #17
thermal-medics.com
compressor checkout
The posts are right on about the compressor or wire short. If it trips the breaker immediately after start up and all of the wire terminals are attached with no burnt ends or anything obvious then I would say the compressor is probably locked-up.
If you are not comfortable with checking out the wiring then I would call a pro in. Really it just takes removing some panels and looking at the obvious. If the breaker/fuses trip over time while the unit is operating then the compressor still may be going bad since the wire is heating up over time and the breaker/fuses are doing their job and not burning up wire and starting a fire.
Either way over 15 yrs like the previous posters said I would go new. It sucks eating it up but like they said get a bunch of bids and get the best combo that works for you. There are many factors in a new unit. I have to say the solar is a little bit of a stretch now.
TM
thermal-medics.com
thermal-medics is offline   Reply With Quote
Old 02-11-2012, 03:40 PM   #18
HVAC Tech/ Browns Fan
We are putting in this in customers house in 2 weeks. The cost just for the solars are 10k.
Tator1076 is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 07:48 PM
Aux Heat Not working with Heat Pump quamism HVAC 5 10-26-2011 04:40 PM
heat pump not working kyleGR HVAC 2 05-30-2006 02:35 PM
