Heat Pump Output Correct? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 11:14 AM   #1
Heat pump output correct?
Hi, I have a Lennox XP17 2.5 Tand installed a year ago. Just wondering in my temperature output at the registers is just about normal.
With heat pump running and no heat strips engaged, I am receivng a temp of 80 degrees at the registers.
conditions:
house temp: 68F
outside air temp:14F
Is 80 that I am receiving at the registers normal or am I below what it should be??
tks
carl333 is offline   Reply With Quote
Old 02-05-2012, 11:20 AM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I would think it should be a little higher.
What is the outside temp?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-05-2012, 11:23 AM   #3
14F=outside temp
Old 02-05-2012, 11:34 AM   #4
Rewards Points: 560
At 14 deg the HP isn't very efficiant.
With out knowing pressures I would say it's doing the best it can do.
When was the last time you had the system serviced.
If you don't have an outside thermostat I would advise you to have one installed. So that when the temp outside gets below 25 it cuts out the condenser and turns on the 2nd stage heat. At 14 deg you may be spending more money for very little results versus the same money being spent on 2nd stage heat and providing a better return on heating
I have always told customers that a system needs to be serviced twice a year spring/fall but with heat pumps you should atleast have the system serviced at the end of the summer. Charging techniques are quite different with a HP in the winter. It is much easier to check out a HP in the A/C mode.
Old 02-05-2012, 11:48 AM   #5
The HP is a year old. Actually I have a dual energy system with oil as back-up. The HP will run until 10F or so, then the secondary source oil kicks in.
I haven't considered having it serviced just yet. What servicing would be done on a unit this old?
Right now, its about 15F, and its running about 60% of the time. Do you think its not efficient to run and I should have expensive oil kick in?
I live in Quebec and our electrity rates are very, very inexpensive.
Are you impressed with the 80F at the registers or should I have it serviced? I just want to get the max. efficiency out of the HP and not sure what I am getting at the registers is about normal.
Old 02-05-2012, 11:49 AM   #6
Old 02-05-2012, 12:06 PM   #7
Rewards Points: 560
10 deg is too low I normally set kick out at 25 deg. HP loose their efficieny drastically below 27 deg
Even at a year old freon can leak out. Though it shouldn't I would still have the charge checked every year.
At 15 deg no I don't think it is very efficient. When you compare the BTU's you get from electric at 15 deg compared to oil I think you will benifit from oil.
Are you impressed with the 80F at the registers or should I have it serviced? I just want to get the max. efficiency out of the HP and not sure what I am getting at the registers is about normal.[/quote]
Old 02-05-2012, 12:09 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 1,800
That is a VERY high end unit and should be checked once a year. The covers on the outdoor unit need careful removal and the coil washed with a hose. Freon levels should be checked. GENERALLY if there is a freon leak it shows up in the first yr of operation and if it still has any of the 1 yr labor warranty left you should get it checked ASAP. Tech will check the superheat/freon level/outputs etc. To keep the warranty going properly ( has a 10 yrs parts warranty on that unit I believe) it should be checked once a yr. We have another tech Marty who may be here later (if not watching the Super Bowl) who does a lot of Lennox and has a XP15 himself. Hang in here.
The Following User Says Thank You to yuri For This Useful Post:
Plumber101 (02-05-2012)
Old 02-05-2012, 12:12 PM   #9
tks Yuri. I HOPE Marty chimes in.
Old 02-05-2012, 12:21 PM   #10
Rewards Points: 560
Yuri
Yuri,
Since I don't know Canada climate do you think the kick out temp is right?
Do you think this person should be using oil now or is ok with HP operation?
Old 02-05-2012, 12:22 PM   #11
Hvac Pro
yuri's Avatar
14F = -10C sounds like you are running it WAY too low and I don't do a lot of heatpumps. Like Plumber101 says 25F sounds reasonable to me. 32F = 0C so you would be around -4C which is as far as I would go. Good advice from him. What you are doing now is basically wearing out the compressor and a VERY expensive outdoor fan ECM type so I would rather extend the life of the unit and pay for another fuel source. Your output is probably OK but the ROI return on investment /COP co-efficient of performance is poor at that temp. Why is elec so expensive in Quebec and Ontario. You guys have LOTS of it like Manitoba. Must be due to getting rid of the old nuclear plants and export deals etc. We may get nailed with that as the Manitoba govt/Hydro want to build this Bipole 3 line and more plants up North and guess who gets to pay for it. Moi of course.
Old 02-05-2012, 12:51 PM   #12
Yuri,
Update. I am doing some accurate measuring as we speak.
Outside temp: -7C
HP kicked a few moments ago at 1:07 and it completed a cycle in10 minutes to maintain temp. Shut off at 1:17
HP re-kicked in at 1:32 (15 min. after completion of last cycle) and completed a cycle this time in 12 minutes or 1:44
My earlier post said my electricity rates are very, very INexpensive. Especially due to the fact that Hydro Quebec has a dual energy program where they discount hydro rates at 30% less that all the other hydro uses around me that are not on a dual energy program. Our electricity rates are probably second to now in the rest of Canada and I am being further discounted. YAAA!!! So I don't mind running elect. to run my HP for as long as it wishes just as long as its less expensive than oil. If running a HP involves a lot of wear and tear on compressors etc...then I may consider having the oil kick in sooner rather than later but not sure where the trade off is exactly. So many variables to consider, so that's why i need advise from the experts here. Comments?
Right now, the system as it is set up, oil takes over and kicks in at approx. --14C. Sure, the HP runs almost continiously just prior to hitting that temp....
Am I exerting the HP recklessly or am I on track to to run the HP as is considering the low elect. rates I am receiving?
I am going away from my 1st question which was about getting your opinions of the 80F reading at the registers solely from the HP. Am I doing good? Comments?
Old 02-05-2012, 01:04 PM   #13
An old Tradesmen
Rewards Points: 6,860
HP is virtually always more cost effective then oil back up. If its able to maintain indoor set temp, leave it run.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
hvactech126 (02-05-2012), yuri (02-05-2012)
Old 02-05-2012, 01:07 PM   #14
Hvac Pro
yuri's Avatar
OK, I did not read the IN expensive part, apparently Ontario is expensive but they have some old nuclear reactors off line and needing expensive repairs. The compressor is designed to run continuos and the outdoor motor has ball bearings but I would rather not wear the unit out. Most people can't stand that low of a supply temp but obviously you can and your cycles are nice and short so if the shoe fits wear it. I doubt you can get more than 80 deg supply as the output drops like an inverted bell curve in proportion to the outdoor temp. Obviously Lennox does not have a problem with that setting and the new modern high efficiency units are designed to run longer and more efficiently than the older ones. Yours is 17 SEER and that is very high. Get it properly serviced when it is at least 70 F or 22C in the spring and then you have no worries. It has lots of safety controls to monitor itself so I doubt any damage can occur but it still needs checking. When you buy a Lexus you want to protect your investment not like some cheap thowaway car. With the outdoor coil now being dirty after a yr you may be losing some performance.
Beenthere knows a lot about them so I guess the consensus is let it run if you don't mind the wear and tear aspect and cool supply temp.
Old 02-05-2012, 01:19 PM   #15
Thanks for all your replies guys. I appreciate it. Just 1 last ?? if I may.
Is the temperature at -14C when the oil kicks in decided by Lennox as a factory setting or could it have been the tech guy who installed it that made that decision? I would think Lennox.
opps! One last but just out of curiousity. Can the oil kick in temperature be decided by me at adjustments made at the thremostat? I have a White Rogers kick ass thermo as implied by the teck guy who uses nothing else. Old school or what? Good thermo?
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
American standard heat pump question. SS laser HVAC 5 01-04-2012 09:35 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
Goodman Heat Pump - Blower Motor FireFighter254 HVAC 9 03-05-2010 06:18 AM
Heat pump vs in floor heat mugen HVAC 5 03-02-2010 08:18 PM
