Heat Pump Oil - HVAC - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 10:35 PM   #1
Heat Pump Oil
I have two heat pumps that were stolen and recovered but I know oil spilled out of one of them, how do you determine how much oil needs to be added during re-installation? Will most HVAC contractors know how to do this or is there specific instructions that I need to provide?
pboneil is offline   Reply With Quote
Old 03-26-2012, 04:09 AM   #2
An old Tradesmen
Rewards Points: 7,818
Only way is to remove the compressor, and poor out the oil and measure how much is left.
Old 03-26-2012, 09:22 AM   #3
I have a refrigeration oil pump that I use to remove contaminated oil from refrigeration systems. No reason it can't be used on a heat pump.
Just ask the guys if they have an oil pump to remove remaining oil and measure it against the factory oil charge.
pouring it out is fine, just not as accurate.
hvac5646 is offline   Reply With Quote
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
