heat pump not working
Check all circuit breakers/fuses in panel and the outside cut-off.
Sounds like the compressor isn't working, or you're low on freon.
If all brekaers/fuses are O.K., then call a service tech to check the freon and replace as necessary.
Good Luck!
Mike
To check breakers, flip all the way off, then back on.
To check fuses, remove from fuse block, and check fuse by holding both leads of an ohm meter on each metal end of the fuse. If the needle doesn't move, the fuse is bad.
