Old 03-12-2012, 05:10 AM   #16
An old Tradesmen
Heat pump is not running on Heat mode
At 0 degrees outdoor temp. Many heat pumps still use 1/3 less electric for every BTU they provide over electric strip heat.
Some older ones(8 SEERs) are only as efficient as electric strip heaters when its 0 outside.
Old 03-12-2012, 05:10 AM   #17
An old Tradesmen
Old 03-13-2012, 04:34 AM   #18
Professional
here is the info on this heat pump it is not 8 seer. http://www.commercial.carrier.com/wc...PRD710,00.html
The HP should still be more efficient that the aux at 0F
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
frank06 (03-14-2012)
Tags
carrier heat pump, no heat
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 08:06 AM
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 08:07 AM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 04:42 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
