Heat Pump No A/c - HVAC - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 10:57 AM   #1
heat pump no a/c
I just had a leak repaired, vacuumed and filled with freeon. Now, about 2 weeks later, the air is not cool. The fan and all is working just not cooling. Is it possible not enough freeon was added or am I looking at another leak or some other complication from the first repair?
cyras21 is offline   Reply With Quote
Old 05-23-2011, 11:39 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Is it working in heating mode?
Doc Holliday is offline   Reply With Quote
Old 05-23-2011, 12:06 PM   #3
yes...
Old 05-23-2011, 12:47 PM   #4
Reversing valve may be stuck.
Check for voltage at the reversing valve or have a tech check it. If voltage is getting to the reversing valve in cooling mode, sometimes all it takes is a good tap.
Old 05-23-2011, 01:27 PM   #5
what should I look for (to identify the valve) or can I just kick the whole thing? lol
Old 05-23-2011, 01:56 PM   #6
It will look like so
and it will be on the inside of the unit which means you'll have to remove the service covers and dig in there a bit. Be careful, turn the power off by way of breaker or disconnect and not just the stat (you will still have high voltage out there if only stat is off) to the unit first.
Old 05-23-2011, 06:49 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
if this repair was done 2 weeks ago, you need to call the repair company that did it.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
