Heat Pump To New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 12:48 AM   #1
Heat pump to new thermostat
My heat pump is a American Standard Heritage 10 (6H0036A100A3). The wiring for the system contained 8 wires. I bought a new thermostat (Honeywell RTH7600D) but am having trouble wiring it. I am not getting any heat from the system. The wires in the old thermostat were marked as follows...
Old System set up (color wire):
R (red)
G (green)
Y (yellow)
X (black)
E (brown)
O (orange)
W2 (white)
W3 (blue)
New System inputs (Honeywell RTH7600D) with my connections:
C (black)
G (green)
Y (yellow)
O/B (orange)
RC (connected to R)
R (connected to RC) (red)
AUX (white)
E (brown)
L
***Blue wire is not connected to anything
cuskeja is offline   Reply With Quote
Old 10-18-2012, 06:31 AM   #2
An old Tradesmen
Rewards Points: 6,516
Did you go into installer set up and tell it you are connecting it to a heat pump.
Should have gotten one that does 3 sages of heat. You will probably have to also connect blue to aux.
Old 10-18-2012, 10:43 AM   #3
It did not give me option to input that it was a heat pump in the set up. Only wiring had arrows pointing for letters associated with heat pimp. Another issue was when the old thermostat was on the white wire was attached to W2 and blue was attached to W3. The new system does not have a W3.
Old 10-18-2012, 03:05 PM   #4
An old Tradesmen
It gave you the option in set up #170, that should be set to 7.
Yes, its only a 2 stage heat thermostat. A 3 stage would work better.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (10-19-2012)
New heat pump wiring question jmedenf HVAC 3 10-14-2011 07:26 PM
Heat Pump Thermostat wiring SHBicycle HVAC 23 03-15-2011 03:28 PM
Hunter Thermostat Model 44860 Heat Pump Emergency Heat Does Not Work On Auto stvnhdmpa HVAC 8 12-08-2010 06:44 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 01:54 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
