Heat Pump Model Number - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 02:33 PM   #1
I am trying to figure out the manufacturer of my Heat Pump unit. I have the schematic, however it is quite weathered and I am only able to make out the following:
Heat Pump Model HB030/036KOW.
The unit is one of the self contained that hangs on the side of the building. I have seen them used alot for construction trailers, etc.
I am trying to diagnose whether I have a bad capacitor or not. It used to work back in the fall. Now the blower will come on and blow air through the ducts. However, neither the Compressor or the cooling fan (fan that blows air across the cooling coils) will come on. I see where there are two capacitors-- one for the compressor and one for the fan.
My question is would one bad capacitor cause the other unit to not function. Bad capacitor on the Compressor cause the cooling fan to not turn on and vice versa.
Thanks in advance for any insight into the manufacturer or any other suggestions.
Thanks-
GTrussville is offline   Reply With Quote
Old 05-26-2009, 05:44 PM   #2
An old Tradesmen
Rewards Points: 6,068
So your unit has 3 capacitors?
1 for the indoor fan
1 for the outdoor fan
1 for the compressor
Old 06-03-2009, 12:03 PM   #3
Correct it has 3 capacitors. However, on further investigation I found that for whatever reason the contactor was sticking on one side. I am not certain why. When I turned the breaker off, I noticed that the contactor did not drop out on one side. I pushed it in and out a time or two and it seemed to free up. I then reapplied power and everything seemed to be working correctly. The outdoor fan was blowing the compressor was kicking on and it was blowing cold air in the house. I am thinking about changing out the contactor. Evidently it was not the capacitors as I had suspected. Also, I did a little more investigation and was able to find the model number for the entire unit complete with manufacturer.
Thanks for your response.
Please answer this question about my Carrier Heat Pump... jifmom HVAC 4 02-20-2009 12:38 PM
Heat Pump czars HVAC 3 02-06-2009 09:49 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
