Heat Pump Makes A "Wah Uhh Wah Uhh" Sound - HVAC - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 10:01 AM   #1
Heat pump makes a "Wah uhh Wah Uhh" sound
Please let me explain. I have two heat pumps. One for up one for down stairs. Both get yearly maintenance. One runs just fine. The standard hum sound. Recently the other started making a different sound as it sounds more like it oscilates with a "wah uh wah uh" cadence. Both units work fine. No issues. just the sound . Any ideas?
Jaredkm is offline   Reply With Quote
Old 04-30-2011, 11:47 AM   #2
An old Tradesmen
Rewards Points: 7,814
Could that one or both coils are dirty, or that its low on refrigerant.
Old 04-30-2011, 11:46 PM   #3
Question
heat pump coils
\I took the sides off my heat pump to clean. there was a 3 inch line of bent fins all around the inside of the crated cond.service coil. repair guy thought i hit with weed eater. It,s on the inside. Would that be my r-22 leak? He cant find any other.He thinks it is because he cant find it.do installers put those toghter at factory?
billmill5050 is offline   Reply With Quote
Old 05-01-2011, 04:06 AM   #4
An old Tradesmen
The bent over fins, sound like its not sitting on pump ups, and the water from defrost couldn't drain right, and refroze and bent the over. Seldom is that area where the leak is, but its always possible.
The units are assembled at the factory.
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
heat pump question David from MD HVAC 3 02-01-2010 08:42 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
