Old 04-20-2010, 08:38 PM   #1
Heat Pump Low Voltage Wiring
have a new Duro Guard Heat Pump it has the low voltage wiring of Y B C R D on the circuit board. my stat has the Y R G C W O connections on it. The problem is if I wire up the B on the Heat Pump the reversing valve clicks and the heat cycle is engaged, If I take the B wire off the valve clicks and the cool mode is working. this is backwards. the valve engaged should be in the cool mode. can any one tell me what is wrong here.
bobolink2000 is offline   Reply With Quote
Old 04-21-2010, 07:20 AM   #2
An old Tradesmen
Its a Rheem product, and that is how they are suppose to work. Energized in heat mode, de-energized in cooling mode.
Go into your installer set up menu. Look for the setting to change the O to energize the RV in heat mode.
Old 04-21-2010, 06:50 PM   #3
I don't have a installer set up menu, but I know now that Duro Guard is energized in the heat mode, not the cooling mode. Thanks.
Old 04-21-2010, 08:39 PM   #4
yep, rheem ruuds are backwards from everything else.
The Following User Says Thank You to Marty S. For This Useful Post:
bobolink2000 (04-22-2010)
Old 04-24-2010, 11:02 PM   #5
i never understood why rheem does that. It seems like if your heat pump pooped out you would at least like to have some heat in the winter
tamar120 is offline   Reply With Quote
Old 04-25-2010, 11:28 AM   #6
My stat does not have the (B) on it for the heat mode, I guess I'll have to change the stat out. I don't think there is any other way.
Old 04-25-2010, 01:00 PM   #7
An old Tradesmen
I don't recall in recent years having seen any thermostat that has a O terminal that couldn't be configured to operate as a B terminal.
What brand and model number is your thermostat.
Old 04-25-2010, 01:21 PM   #8
I'am not at the home where the stat is, I don't know the model or brand name, it is a older stat has the R Y W G C O on the stat. I could not fine a switch that goes between 0 or B on it.
Old 04-25-2010, 01:54 PM   #9
An old Tradesmen
Depending how old. You may indeed need to get another thermostat.
Old 05-01-2010, 10:23 AM   #10
I have a new Duro Guard Heat Pump. with the terminals (C) (R) (B) (Y) (D) and a new stat LUX-750 the terminals are (E)(G)(Y)(R)(X)(0)(W2)(B). The Furance is Electric How do I wire this so my rev. Valve will work in the heat mode.and the A/C will work in the cool mode. and heat strips will work in the emg. heat mode. and the heat pump will work in lst stage heat?
Old 05-01-2010, 10:50 AM   #11
e=white wire for elec heat
g=green wire for fan
y=yellow for outside unit
r= red for power
x=blue or black for common(have to look in air hand to figure out which color is being used for common)
O=not used for your application
w2 jumper wire to e term
b= reversing valve (usually orange)
kennzz05 is offline   Reply With Quote
The Following User Says Thank You to kennzz05 For This Useful Post:
bobolink2000 (05-01-2010)
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 07:32 PM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 10:46 PM
Heat Pump Control Wiring Questions IBuiltPools HVAC 3 01-14-2010 02:45 PM
Electric Wiring for Pool Heater (heat pump) tazmajazz Electrical 7 10-21-2009 09:49 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
